I can scan Maneti marellli 4sgf iaw
Daniel_fe
Post by Daniel_fe »
Hello Yanni:
I need to know if your software I can scan a ECU Magneti Marelli IAW 4SGF of a Palio Weed End 2007 Brazilian motor 1.4 8v. The protocol of the ECU is OBDII?. It runs some danger building and testing the connector to communicate with the ecu?
Any advice, suggestions and / or information is welcome
Daniel :D
Santa Fe, Argentina
gsune
Re: I can scan Maneti marellli 4sgf iaw
Post by gsune »
Hi i have a fiat palio whith ecu magnetti marelli iaw 4sgf si
i think that it isn´t working. there is not spark, no injector pulse, no comunication whith the scantool, and the fuel pump is alwais on.
help me please
Daniel_fe
Post by Daniel_fe »
gsune wrote:Hi i have a fiat palio whith ecu magnetti marelli iaw 4sgf si
help me please
Is rare. the ecu with scantool communicated before :?: ? The symptoms are like no control of the ECU.
I think we must first see if there is voltage to ECU. Patience
PD: where are you?
Greetings
Santa Fe Argentina
gsune
Post by gsune »
Venezuela. hablo español
gsune
Post by gsune »
The boy in the garage put the negative wire in positive ...
now the fuel pump is working properly but there is not spark.
i need the schematic diagram of this ecu
El mecanico habia puesto el un cable negativo en el positivo.
ahora la bomba de gasolina está normal pero no hay chispa.
sorry writing in spanish
Daniel_fe
Post by Daniel_fe »
Tengo algunos archivos comprimidos de la iaw 4sf (no 4sgf), pero creo que el pinout es el mismo. Si querés mandame un mail propio, por que los mails privados de este foro no me acepta ningun formato de archivo atachado
Saludos
gsune
Post by gsune »
Mi correo es gsune@hotmail.com
Gracias amigo
VEQUI
Post by VEQUI »
Daniel_fe wrote:Tengo algunos archivos comprimidos de la iaw 4sf (no 4sgf), pero creo que el pinout es el mismo. Si querés mandame un mail propio, por que los mails privados de este foro no me acepta ningun formato de archivo atachado
Saludos
Tambien yo necesito el diagrama de la ecu IAW 4SGF mi mai es vequivelez@gmail.com si podes enviarmelo te voy a estar muy agradecido
