Multiecuscan 2.5 RELEASED!
I released version 2.5 today.
The main changes in this version are:
- Fixed the problem with ME 3.1 and VagCom interface
- Added function to detect available serial ports in the system
- Changed FREE version to show in red the modules that are not free
- Added CAN Info function (shows CAN configuration)
- Added Bosch Motronic M2.10.3 support
- Added Bosch Motronic M3.7.1 support
- Added TRW Electric Power Steering (Croma) support (also in FREE version)
- Added SAGEM Power Steering (Thesis, Ducato) support
- Added Marelli Body Computer (Thesis) support
- Added Nippon Instrument Panel (Thesis) support
- Added Lancia Thesis Service Interval Reset
- Added Lancia Ypsilon Service Interval Reset
- Added Siemens VDO Instrument Panel (Ypsilon) support
- Added SELESPEED CFC218F Automatic Gearbox (156 GTA) support
- Added ABS Teves MK20/MK70 (Brava/Bravo) support (also in FREE version)
- Added Bosch ABS 5.3 ASR/TC(Punto, Ducato, 156 GTA, 166, GTV, SPIDER, LYBRA) support
I need "CAN Info" report from a Stilo that has factory cruise control.
Re: Multiecuscan 2.5 RELEASED!
Hi, i have a Stilo abarth with factory cruise esp ecc. but i have only free version. Tell me if i can help you.
The "CAN Info" module works in the free version, but you need ELM 327 interface to connect.maxri wrote:Hi, i have a Stilo abarth with factory cruise esp ecc. but i have only free version. Tell me if i can help you.
So, if you have an ELM327 interface then just connect to "CAN Info", then disconnect and click the small red button "Send Report" which appears on the bottom right part of the main window after disconnecting from any module.
I have elm 327.. so i will try to do it.
i read and send within notime
greets wilco1v
greets wilco1v
Thanks to everyone who sent Stilo reports.
I now know how to make the cruise control light on dashboard work properly.
I just tested this on my Stilo and it WORKS!!!
Unfortunately, this is a part of the Proxy Alignment procedure and you will have to wait for next version of Multiecuscan to use this function ...
Yani,
When do you expect to release the next version with proxy alignment included?
For the proxy alignment do you need the body computer codes?
I have an Alfa 147 and I installed a connect nav, now have the instrument panel blinking!!!
This software solves my problem??? Thanks
Ps: sry my english
Ps: sry my english
Ps: sry my english
Ps: sry my english
good job, excellentyani wrote:Thanks to everyone who sent Stilo reports.
