good evening
can not connect with fiateuscan Cable KKL a netbook asus eeepc 1001 h 1.60 ghz and 1 gb of ram win xp even after setting up the com ports.
the cable works fine with a notbook win vista
What can I do?
thanks
Asus does not work with eepcc multiecuscan
Re: Asus does not work with eepcc multiecuscan
my Asus 1005HA windows seven starter works perfect with KKL VAG cable and multiecuscan. should be the same for yours. try to change com port settings again in windows parameters.
