Hi Yani,
Thanks for this great program.
This is my problem:
I use Multiecuscan 2.4.1 register with a KKL Vagcom with pin 1 connected.
Everything is ok except for the airbag ecu : software try to connect and...no connection!
I've tried all the six types of airbag but nothing.
I have made a test on a Panda 1.3jtd 2007 : same thing.
Maybe my new vagcom is defect...
Any idea?
Thanks and sorry for my english
no connection with airbag stilo abarth
Re: no connection with airbag stilo abarth
You need to connect pin 3 for the airbags.
Oh sorry I made a mistake in my description : pin 3 is connected, not pin 1....
Check with a multimeter if you have connection line K with pin3.gbbt wrote:Oh sorry I made a mistake in my description : pin 3 is connected, not pin 1....
BAS
thanks for your reply.
Yes, I have connection from pin 3 to pin 7 with my multimeter.
I don't understand.
I don't understand.
Should be pin 3 or pin 7 not both linked.
You need to be able to switch the feed from pin 7 to the
circuit board off and replace with the feed from pin 3
by fitting additional wires and a minature switch.
John
John
