ELMScan5 connections
Tanis8472
Post by Tanis8472 »
Hi guys,
I will try again to post on here :(
I purchased ELMScan 5 V1.4 and OBDWiz from Scantool-Direct.co.uk
http://www.scantool-direct.co.uk/produc ... ic_Kit_st1
It says it is 100% compatible with FES.
Now the problem I have is that I cannot connect to the module from the settings page when clicking on Test.
I have the port and speed settings as suggested.
I have also tried the tool on the disk to find ELMScan. It cant find it either.
mattydr67
Re: ELMScan5 connections
Post by mattydr67 »
You can do that if you plug your interface in the car.
Just when the interface is pluging in the car you can do the "TEST"
Or just plug 12V on pin 16 (+) and pins 4 and 5 (-, ground)
Tanis8472
Post by Tanis8472 »
ah, i see. that explains all. many thanks :)
