AR 159 2,4JTDm servise interval
cendler
Post by cendler »
I have a problem with AR 2.4 JTDM (2006), and flashes me a service interval, I ELM327 1.4 and unregistered Multiecuscan program and still writes to me that if I give SERVICE - connection error when I connect to the engine, so it is no problem . and everything works, only the service interval is not me, you do not know what it is?
1 unregistered Multiecuscan?
2nd bad cable?
3rd someone played with miles and something wrong?
Sorry for English, I can power it.
Re: AR 159 2,4JTDm servise interval
The unregistered version of Multiecuscan will NOT do a Service Reset. Registered version is required.
cendler
Post by cendler »
OK, so if I have a registered version, so it will definitely work?
It should work! You can check other post and you can see the experience from other people! ;)
