Hi all,
This is my first post so I would like to thank Yani for all his hard work writing a cracking good piece of software.
I have an '02 Stilo 1.8 16v Dymanique with various problems including airbag warnings and ABS ASR and ESP warnings so I am working through them 1 by 1.
When I read the codes from the ABS module I get the following
C1460 Brake fluid Pressure switch faulty
My question is.... Is this switch built into the ABS unit or is it something I can swap out
Many thanks in advance
David
stilo brake fluid pressure switch
Re: stilo brake fluid pressure switch
Hi many times the "ABS ASR and ESP" is caused by an defectiv breakpedal-switch! (the little one attacted at the break pedal!)
Airbag erros many times by the cable unter the seat.
Good luck !
Good luck !
