I own a 147 JTD 8V from the year 2002. I have some little problems with driving when cold. The engine sometimes stalls or sometimes does have the intention to stall. I then have to push the pedal much too far then usual to keep the car going.
Besides that the car runs just fine and last week i'ver tested it in germany and it still reached 194 km/h on gps after 175.000 km, so i was pretty amazed
I think of two options myself that might cause the problem.
1) The temperature sensor
2) The MAF Sensor
I however don't know how to measure the MAF sensor. Measuring the boost pressure is like full throttle in 4th gear from 1000 rpm till 4500 rpm. Is measurement for the MAF the same? And which numbers would be right then?
Thanks in advance for the replies!
