Grande punto support
I have problem with airbag light grande punto 1.3 MJ. I am interested when be support for this drive.
Re: Grande punto support
Maybe into the new relise if Yani will finish the tests and of course that will be ok.
Ok you can try Airbag releise from another car if maybe they are the same.
Choose an airbag on CAN and the sw will tell if it's or not you Airbag. The sw will ask you to press Y if you want to continue or N if you don't. If the sw will show you this messege you'll now that in your car is installed a diffren AirBag ECU and you can try again with another Airbag ECU ( CAN AirBag ). If you'll connect without any messege, you're lucky, you'll can dignose your AirBag.
