Works KKL USB INTERFACE with multiecuscan without soldering ?
darioyu
Post by darioyu »
HELLO !
I have one question about that.
I will like to use KKL VAG usb interface with multiecuscan.
Works KKL USB INTERFACE with multiecuscan without soldering wire to 1,7,9 pin ?
Do i have to solder a short wire to 1,7,9, pin ?
Is it working (abs, airbag) without soldering a short wire ?
Please answer me.
THANK you !
Re: Works KKL USB INTERFACE with multiecuscan without solderi
The KKL interface will work without making the wiring modifications BUT WILL ONLY GIVE YOU ENGINE ECU information.
To connect to ABS, Airbags etc. then pin 7 must be connected to the relevant pin.
darioyu
Post by darioyu »
thank you for answer !
Can i connect all pins 1,3,7,9 together ?
CAn i damage the car or cable if i do that ?
Thank you !
See this: viewtopic.php?f=6&t=1499
It is not recommended to connect all the pins together. Much better to use DIP switches or an EOBD patch box.
