Bonnet sensor alfa 159 SW
illiac4
Post by illiac4 »
Hi!
Today i was playing with version 2.4 and have found something strange. I think there must be something wrong.
So the alarm mode was set to 0. I have changed it to 1 and after i have changed i saw the error that Bonnet is open. So after changing back the alarm mode to 0 turned off that error.
If i check the Bonnet status under Parameters it is 'open'.
Where is the sensor for the Bonnet and do you think that it is ok that the alarm is set to 0?
TNX
Re: Bonnet sensor alfa 159 SW
Alarm mode 0 disables all alarm events.
If the alarm mode is >0 and you open a door without unlocking the car then the direction indicators begin to flash rapidly. The same happens if you try to lock the car and a door is open.
It seems that your bonnet (That should be the upper boot lid. I'm not sure if all SWs have this option. My Stilo MW has it.) sensor is damaged. The sensor should be inside the locking device (I guess).
illiac4
Post by illiac4 »
Hmmm strange. Even if the alarm mode is set to 0 the door open alarm still works and back lid also. So i assume that the seller (Fiat) just disabled the warning so the did not need to repair the sensor. But it is strange that only bootle is not showing when alarm is set to 0, all other doors and boot lid are.
Boot lid is in back and bonnet is front where engine is.
Disabling alarm mode has nothing to do with ECU and machine warning or? Just body parts?
illiac4
Post by illiac4 »
Obviously my Alfa does not have this sensor and from there has come the error.
I thought that if the sensors are there for doors and boot lid, i thought that there is also for bonnet,but obviously not.
Well tnx again.
