ELM327
scan
ELM327
Post by scan »
I have an elm327 modified with switch. I can run the test on FES at 38400baud and everything is OK.
On my Stilo 1.9 JTD 115, I can connect to ABS/ESP on pin 1, Engine on pin 7, Steering on pin 9.
I also connected pins 12 and 13 with switch. I am unable to connect to Body, dashboard, parking controller, and others.
What might be wrong? Which other pins I should connect to the dip switch?
Re: ELM327
It seems that your interface cannot connect to CAN.
Did you try the "Test" function in Settings? All commands there should have OK as response.
scan
Re: ELM327
Post by scan »
As I remember all tests were ok. I will try again in the morning and post the results.
scan
Re: ELM327
Post by scan »
I have tried to send report, but the internet connection was poor and I don't think any of the reports were sent.
I have a suggestion. Could you please make an option to save the report as text for later sending? Usually in the car is no internet connection.
Here is the test output, run from the Settings window:
RESPONSE: ATZ
ELM327 v1.5a
RESPONSE: ?
RESPONSE: ?
RESPONSE:
ELM327 v1.5a
Do you need me to connect with a serial terminal like terraterm and issue some AT commands? I think can do that.
Re: ELM327
This interface is ELM 1.2 clone. It cannot connect to Fiat CAN.
Re: ELM327
scan wrote:COMMAND: ATZ
RESPONSE: ATZ
ELM327 v1.5a
As has been pointed out there is no ELM327 v1.5a interface. The latest offical version of the ELM chip is V1.4
mattydr67
Re: ELM327
Post by mattydr67 »
That version of ELM327 I saw it 1.2 or 1.3a
Depend of your luck.
If it's 1.2 you cannot connect just on ECU but if is 1.3a you can connect to everything, well whitout Airbag on k-line.
The last ELM327 version is 1.4
yincar
Re: ELM327
Post by yincar »
hi all,
Is anyone out there can direct me to the website or retailer that selling "working" clone or original ELM cables? I'm planning to purchase the software but before that i need to get the cable in first.
thanks,
yincar
yincar
Re: ELM327
Post by yincar »
hi all,
anyone in the forum can share where you bought your ELM 327 cable that works well with software? I'm planning to get the cable in before placing order for software. Either clone or genuine that woring fine will be very helpful. Website or link will be much appreciated.
thanks,
yincar
mattydr67
Re: ELM327
Post by mattydr67 »
I bought mine from ebay.com
It is chinese clone.
Now I thing that all chinese has version 1.4.
I tried to buy one 1.3a and when I tested it is 1.4
I can't give you a link because the chinese guys don't make me any discount and I won't to make them advertising
Genuine? There's companies who sell their interfaces with elm327 v1.4 original chip inside like Skapang but the price is very high and it dosen't worth it.
I advise you to buy from ebay.
