change alfa 156 selespeed control unit
denchai
Post by denchai »
Hi. every one
I'm newbies. I have some question to ask about when change the alfa 156 new selespeed control unit. Does it need coding or flash program control unit or not?
The old control unit was burnt. After I change the brand new control unit and calibrate everything the gear box work fine ,but after few days it 's stuck at neutral and
cannot move in any gear.When read fault code it show no coding or something like this.After clear fault code gear box still not work . I try to calibrate every thing again,
It still not work. But after fault code is clear 2-3 hours the gear box back to work again ,I didn't do any thing. So I'm not sure about the control unit need to be coding or flash
program or not to make it working properly? And I look at the FES program it does not show the menu coding or flash program at the selespeed menu How should I do?
The selespeed control unit is CFC202F.01.
