Speedometer replacement due to AdBlue
The old speedometer only had a warning light for AdBlue.
The new speedometer has an AdBlue tank gauge.
Proxy alignment not possible
An error message appears
The motorhome does not have PDC (Park Distance Control)
However, PDC appears on the new speedometer
Is it possible to delete the PDC?
Old speedometer: 503.016.020.322
1395350080
New speedometer: 571.016.020.132
00468644540
Exchange
Proxy Speedometer change PDC
Logitech12
abarthmultijet
Re: Proxy Speedometer change PDC
After an failed proxy you can press a little pdf button on the botom right corner of the MES homescreen. Post the results of that pdf here.
Logitech12
As requested, here is the PDF.
Hano tacho.pdf- (411.49 KiB) Downloaded 55 times
Logitech12
Speedometer recalibration worked.
All error codes were cleared.
Unfortunately, the AdBlue tank gauge has become a temperature gauge.
Which byte code is responsible for this?
And how does it need to be reprogrammed?
Here are the proxy details.
30 38 32 35 30 34 33 34 30 33 31 4F 55 54 50 55 54 44 4A 49 54 20 20 02 22 4B 18 40 04 00 02 00 00 09 00 00 04 00 00 00 00 03 40 53 08 B1 00 AB 20 00 00 00 16 00 00 00 8C 06 0B 02 60 C0 02 D6 04 05 00 05 04 00 00 00 00 56 00 00 00 00 36 00 D3 03 11 34 00 98 00 AD 00 A0 10 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 64 00 00 00 00 00 00 85 17 00 04 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 1F 00 00 04 20 00 02 FF
