Hello, I have a 2006 Fiat Panda 2 with a 1.1 engine and I wanted to install the emotion version of the instrument cluster because it originally had a cluster without RPM gauge. I installed the cluster, but the display is flashing, so I wanted to perform proxy alignment, but the "Dashboard Node (IPC/NQS)" says "FAILED! - Unknown error". Someone suggested that I should change the proxy configuration manually, but I don't know which byte to change. I think this might work because when I compared the "CAN CONFIGURATION DATA" with the original cluster installed and the one with the emotion cluster, byte 40 is different, so I think there's something wrong. I'm attaching a log from MultiEcuScan showing the configuration with the original cluster and the one with the emotion cluster. Please help, I would be very grateful.
Original cluster:
CAN CONFIGURATION DATA:
00 00 00 0F 00 00 00 0F 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 0F 00 00 00 09 00 00 00 0F 00 00 00 09 00 00 00 09
33 32 31 36 39 30 30 30 36 33 37 4F 55 54 50 55 54 4A 49 54 20 20 05 03 22 0F 00 00 00 09 00 00 00 01 00 00 00 00 01 14 00 00 00 04 06 01 00 00 00 00 00 00 11 00 04
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
(Multiecuscan 4.6R1)
2026-02-01 14:37:18
Fiat Panda '03 1.1 8V
New cluster:
00 00 00 0F 00 00 00 09 00 00 00 0F 00 00 00 09 00 00 00 01
2026-02-01 09:43:08
Dashboard Node (IPC/NQS): EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (IPC/NQS) FAILED! - Unknown error
FAILED TO EXECUTE
Fiat Panda 2 1.1 New dashboard problem
Re: Fiat Panda 2 1.1 New dashboard problem
Proxy alignment was successfully performed with the new emotion counter - I used the ELM327 cable interface - previously I used the Bluetooth version
abarthmultijet
After a failed proxy you can press at a pdf picture at the main screen (bottom right corner). Post that result please
There's no need for that, because the emotion counter is already working fine. But thanks for the reply
