Proxy alignment what do i need?
Jessy1984
Post by Jessy1984 »
Hi i have been reading a lot on forum and info but don't find a clear answer i am looking for.
I have an autel so i can do a lot with that.
But for proxy it seems this is the only solution.
What do i need to buy for hardware . What is best ?
Most i have problems with is the fiat 500. And also ford Ka with is about the same.. also one alfa that also has a flashing ipc.
To program a new module is easy but i need to remove them as its not needed or a different radio is in it.
I see elm should be a good cheap option. But there are so many different cables. I wouldnt know what to order.
Thanks upfront
Re: Proxy alignment what do i need?
Start by reading here: https://www.multiecuscan.net/SupportedVehiclesList.aspx
This details each of the supported vehicles and what interfaces and cables are required.
Suggest you only by kit from one of the authorised distributors (https://www.multiecuscan.net/Distributors.aspx) to avoid the many problems people have with cheap Chinese ELM clones.
Personally I use OBDLink SX which is a wired connection as opposed to blue tooth.
Jessy1984
Post by Jessy1984 »
Thank you for the info.
It seems i can not order the sx anymore. Only the Ex is that somewhat the same?
It says mainly for forscan..
I was not aware that the SX is no longer available. A very quick internet search seems to indicate that the EX is not as good/reliable as the SX, but I could be wrong. If this is the case then go with ELM from a reputable / recommended supplier.
I see on the Gendan UK Site they now list/supply the Genuine Vgate vLinker FS USB Diagnostic Interface (faster than ELM327).
All I can suggest is to contact on the the distributors (there are several in the EU) and seek their advice.
The may be others here that have more recent experience. I got my kit several years ago now.
mohamed.abozaid
Post by mohamed.abozaid »
multiecuscan fiat tipo vgate vlinker fs usb activation camera enabled working ?
