I am using MultiECUScan on an iPhone 13, fully licensed, with the Vgate vLinker MS, and having difficulty with proxy alignment timing out on my 2022 Alfa Stelvio Veloce. I can connect, set values, scan, etc., however when doing a proxy alignment, it simply times out for every module.
The website indicates that, "The bundle is suitable for users of iPhone/iPad Multiecuscan app and it does not require the additional YELLOW, BLUE or GRAY adapter cables for Giulia, Stelvio, Tonale, Giulietta.." which is why I purchased this Vgate vLinker, and further states that, "The vLinker MS device is the only Bluetooth interface that can reliably perform PROXI alignment and other special procedures."
I'm not sure what I may be doing wrong. Can you advise?
I am also looking for where I might set byte values, as I'd like to enable neutral from the paddles.
vLinker MS, iOS, '22 Stelvio Veloce
islandalfa
dzindzis11
Re: vLinker MS, iOS, '22 Stelvio Veloce
I believe you also need SGW (Secure Gateway) module bypass attached for anything newer than 2018. I've got vLinker too, and used it without problem on my 2016 500x (no SGW present)
abarthmultijet
Yes, as said before almost certain that your car has an SGW. You can buy SGW bypass cables or a bypass box.
