Please help me with these Error Codes
Red-Bull
Post by Red-Bull »
i got a fiat bravo 1.4sx mj97 with bosch motronic ecu..
i cant use fiatecu because my ecu is not supported yet.. so i justed kwp71diag from sander to get connection to ecu.
today on the highway i noticed loss in engine.. no more power.. but no engine lights or sounds or so.. so i stoped car.. switched off.. started new.. all fine..
So Kwp71diag gives me:
KWP71Diag
test version
written by SanderQV
DebugScreen
COM Port opened
Init started
Init Ready
KeyBytes, count : 5
AD
86
01
94
9D
ID after 5baud init:
ID : 0261 204 007 , 700 402 1620
ID : AW09M0600166 , 6610060M90WA
ID : 46 454 482 , 284 454 64
Read diagnostic faultcodes :
Bytes received: 02 03 83
Bytes received: 02 0D 9D
Could any1 please tell me what these 2 error codes mean ? it is Bosch Motronic MA1.7.3
Re: Please help me with these Error Codes
I think that these 2 errors mean the following:
1. Rpm sensor, Intermittent
2. Lambda sensor, S.C. to Ground
However, I'm not 100% sure about this because these old ECUs use weird protocols and data formats.
Red-Bull
Post by Red-Bull »
Thanks a lot..
by the way.. u check viewtopic.php?f=6&t=521&start=10 ?
I uploaded FIAT 9141 STANDARD.pdf that would help you to implement these ECUs
