Proxy Alignment failed after enabling CarPlay – BCM inaccessible, flashing dashboard, car won't start
santosweb
Post by santosweb »
Hi everyone,
I have a 2017 Fiat Tipo, and I attempted to enable CarPlay by modifying a few configuration bits in Proxy Aligment using Multiecuscan — no hardware changes, no module replacements.
During the process, the Proxy Alignment failed midway, and since then the car has developed the following issues:
Dashboard is flashing non-stop;
I hear clicking/relay noises when turning the ignition on;
The engine won’t start at all;
I can no longer access the BCM via Multiecuscan (connection fails or times out).
I used a USB ELM327 with FTDI chip and the blue adapter for MS-CAN. Battery was fully charged during the procedure.
Now I’m trying to understand:
Is this a recoverable configuration issue I can fix myself by reverting the bits or forcing a new Proxy Alignment? (I backed up the original bits to a notepad before modifying anything)
Or do I need to take it to a shop with a professional diagnostic tool (like Autel or WiTECH) to reset the Proxi configuration or reprogram the BCM?
My main concern:
Is this likely just a software/configuration conflict, or could the BCM or another module be physically damaged?
Any advice or insight would be greatly appreciated!
Thanks in advance.
Re: Proxy Alignment failed after enabling CarPlay – BCM inaccessible, flashing dashboard, car won't start
reset BCM by disconnecting battery negative terminal for couple minutes. this should allow connection to BCM.
also you can check FESLog file what exactly was changed.
