Connect Adaptor
Suggy
Connect Adaptor
Post by Suggy »
Hi all
New to Multiecuscan, Im after reading the ABS ECU but need the mentioned CONNECT ADAPTOR 1/GREEN (OR PIN 1)
Is this something that can be made or do I need to buy 1?
Thanks for looking and any help much appreciated
Re: Connect Adaptor
You can buy or make.
Check your vehicle detailed requirements here: https://www.multiecuscan.net/SupportedVehiclesList.aspx
Also on the right you will see the various adapter wiring details if you want to make your own.
Suggy
Re: Connect Adaptor
Post by Suggy »
Thanks I did find the list and wiring diagrams last night, pulled my OBD brake out box out off retirement, just need a little time to work it out
