Alfa Romeo MiTo Radio to uconnect 5" retrofit proxy problem
simaservis1108
Post by simaservis1108 »
Hi guys,
I put the uconnect 5" to Alfa Romeo MiTo and I make custom proxy.All is OK but odometer blinks.
In BCM there is B1047-4A Incorrect component installed.
Here is original proxy:
30 31 31 34 35 30 30 30 34 33 35 4F 55 54 50 55 54 2D 4A 49 54 20 08 09 02 4F 00 00 04 10 00 00 00 09 00 00 04 10 00 00 00 04 C0 73 07 67 00 61 01 A3 00 00 16 00 05 00 94 06 2D 01 3C 00 00 00 00 7A 51 0A 5C 0D 00 00 00 00 00 00 00 00 31 02 11 04 08 00 00
And here is the custom proxy that the ETM accepts:
30 31 31 34 35 30 30 30 34 33 35 4F 55 54 50 55 54 2D 4A 49 54 20 08 09 02 4F 00 00 04 10 00 00 00 09 00 00 04 10 00 00 00 04 C0 73 07 67 00 61 01 A3 00 00 16 00 05 00 94 06 2D 01 3C 00 00 00 00 7A 51 0A 5C 0D 00 00 00 00 00 00 00 00 31 02 11 04 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 00 00 00 00 00 00 06 00 00 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
After I put custom proxy,all is OK in proxy alignment menu but BCM still reports an error and odometer flashes.
Can anyone help calculatute good proxy?
abarthmultijet
Re: Alfa Romeo MiTo Radio to uconnect 5" retrofit proxy problem
Post by abarthmultijet »
Can you try this one?
30 31 31 34 35 30 30 30 34 33 35 4F 55 54 50 55 54 2D 4A 49 54 20 08 09 02 4F 00 00 04 10 00 00 00 09 00 00 04 10 00 00 00 04 C0 73 07 67 00 61 01 A3 00 00 16 00 05 00 94 06 2D 01 3C 00 00 00 00 7A 51 0A 5C 0D 00 00 00 00 00 00 00 00 31 02 11 04 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 07 00 00 00 00 00 30 00 06 00 00 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
simaservis1108
Just had a chance to retry this as this is a project car.
It unfortunately didn't help.
Althought it disabled the fader.
I think I need to edit radio type in BCM config,it was Bosch MP3 radio now it is uConnect 5".
