Fiat Ducato 250 cluster change
koira
Post by koira »
have here Ducato 250 3.0Multijet with swapped cluster. Mileage is flashing and cannot get proxi done.
Dashboard Node (IPC/NQS) FAILED! - Data out of range error
Car total mileage is 415800km but cannot program this to cluster with MES. Does it matter?
Is the cluster somehow the wrong type or is it the mileage or what could this be? Never had such issues.
Ducato_cluster_node_error.pdf
(464.61 KiB) Downloaded 2422 times
abarthmultijet
Re: Fiat Ducato 250 cluster change
Post by abarthmultijet »
Why did you change the cluster?
