Which cable for DPF regen? Fiat Doblo (type 263)
VaporTrail
Post by VaporTrail »
There is no mention of forced DPF regeneration under "supported modules" nor any clue in the 'supported vehicles list' as to what module controls DPF regeneration and therefore which cables to use?
Fiat Doblo (type 263) 1.6v multijet
There could be a facility for the free version to demonstrate successful connection to your vehicle in order to have confidence that the paid for licensed version will work?
Re: Which cable for DPF regen? Fiat Doblo (type 263)
You should not need an adapter cable. See: https://www.multiecuscan.net/SupportedVehiclesList.aspx
Select your correct ECU and then go to F7-Adjustments. There you will find the Particulate Filter Regeneration.
