Hi There,
I’m currently using MultiEcuScan to diagnose and monitor my Fiat Bravo 1.4 T-Jet 150 HP (2007), which is equipped with the Bosch ME7.9.10 ECU. I'm trying to ensure I have access to all the relevant parameters and features that the software should be able to read or adjust for this car but i notice i im not able to get values for all parameters shown in the software. Is there a list what parameters i should i be able to read out? When making these screenshots the car was running idle.
I added a screenshot where i highlighted two parameters regarding the variable valve timing adjustment. Should i able to get data for this parameters?
Thanks for the help!
Kinds Regards,
Renffr
(From Amsterdam, NL)
Fiat Bravo 2 1.4 T-jet 2007 150 HP | mssing parameters?
- IMG_5032.PNG (228.52 KiB) Viewed 4329 times
- IMG_5029.PNG (253.89 KiB) Viewed 4329 times
Re: Fiat Bravo 2 1.4 T-jet 2007 150 HP | mssing parameters?
When you have actually connected to the relevant ECU (e.g. engine) then MES on the Parameters tab (F4) will show all the coded available parameters that can be read.
To check this out without connecting to the car use the Simulate (F10) mode.
No vvt in Bravo
