Custom Proxy for UConnect 7", 2 x USB and CarPlay Retrofit
JStrongy
Post by JStrongy »
Hey guys...
First off, been a long time reader but only just registered. Reading through the posts on here, have been invaluable!
I have a 2015 500X which originally had UConnect 5" and USB+AUX module.
I've retrofitted a UConnect 7" and 2 x USB+AUX then run a Proxy Alignment - all ok and milage no longer flashing.
Finally, to get CarPlay running I have read that I need to extend the Proxy to 235 bytes and then made the below modifications:
Byte 148= 05 (Uconnect 7)
Byte 157= 01 (CarPlay)
Byte 160= 01 (Android Auto)
My current Proxy is:
33 38 33 33 34 30 31 30 36 30 31 4F 55 54 50 55 54 2D 53 49 54 20 15 06 09 47 00 20 05 00 00 00 00 02 00 00 00 00 00 00 00 47 00 20 05 00 00 00 00 02 00 00 00 00 00 00 00 D9 FA 0E 02 AC 82 07 E2 50 27 89 07 40 10 10 03 A3 28 54 92 01 35 73 14 01 4F 03 34 00 B3 A8 01 49 03 07 00 A2 00 0D FB 00 00 10 01 00 05 03 54 91 05 02 AD 00 52 00 01 8A 13 3D 40 00 05 03 C5 00 D1 24 10 00 00 49 02 81 12 79 42 80 00 00 8B AA 95 71 20 80 80 85 00
The new custom proxy would therefore be:
33 38 33 33 34 30 31 30 35 34 35 4F 55 54 50 55 54 2D 53 49 54 20 15 06 09 4F 04 20 05 10 00 00 00 02 00 00 00 00 00 00 00 4F 04 20 05 10 00 00 00 02 00 00 00 00 00 00 00 D9 FA 0E 02 AC 82 07 E2 50 27 89 07 40 10 10 03 A3 28 54 92 01 35 73 14 01 4F 03 34 00 B3 A8 01 49 03 07 00 A2 00 0D FB 00 00 10 01 00 05 03 54 91 05 02 AD 00 52 00 01 8A 12 3D 40 00 05 03 C5 00 D1 24 10 00 00 49 02 81 12 79 42 80 00 00 8B AA 95 71 20 80 80 85 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I've read horror stories on these forums about custom proxy's bricking cars, so just wanted to post here and someone give it the once over, before I run it!
If someone could, that would be much appreciated!
Thanks in advanced!
abarthmultijet
Re: Custom Proxy for UConnect 7", 2 x USB and CarPlay Retrofit
Post by abarthmultijet »
Can't spot any problem. I usually start with a proxy lengt of 193, if the car does not accept that code then I try 235
There are others out there wih more experience and knowledge than me but have done quite a lot of cars.
JStrongy
Post by JStrongy »
Perfect, thanks for the advise - will give it a whirl tomorrow starting with 193 bytes.
JStrongy
Post by JStrongy »
As per your advise @barthmultijet, I just extended the Proxy to 193 bytes, made the changes I quoted above and the car accepted it.
Very happy to report that CarPlay is now working!
Below was the final Proxy which I used:
Thanks again!
abarthmultijet
Great job!
