Hi team,
I see that version 5.3 has implemented support for Tonale Phev. Is this hardware the same in Renegade/Compass Phev?
So it's 5.3 version 100% compatible with Jeep Phev?
Jeep Renegade 4XE PHEV
abarthmultijet
Re: Jeep Renegade 4XE PHEV
Not quite, you can scan, read and erase codes and you can see live data, and do some adaptations.
But you can not run an proxy allignment. Mes does not support every module.
Maybe the ABS is the unsupported module?abarthmultijet wrote: ↑22 Dec 2024, 13:10 ...
I'd tried to add the ACC keyboard to the steering wheel, following the Jeep forums (change keyboard, disable Cruise control, enable ACC and run proxi) unsuccesfuly using alfaobd 2.5.5 -last version-. With MES 5.1, same error.
Running proxi, at the brake system step, fails with unknown error.
Do you think the 5.3 version could accomplish this job?
Thanks and Happy Christmas!
abarthmultijet
It is always worth the try. Mes 5.1 is really a lot older then 5.3
