ACC Bosch Senzor aligment from MES?
callmemga
Post by callmemga »
So I got an error for the bosch radar, which is missaligned vertically, now, in order to fix it, I heard there's something that can be done from MES, until actual manual aligment is needed?
ACC worked, but failed when i had 2 cars sitting in front of me, sharing the same lane per say, and when that happened for a couple of meters it threw acc error, does anybody know how to do it from MES?
Car is a 2018 giulia veloce, had front crash-bar replaced, acc worked for about 2 and half months after the new crashbar was fitted
Actual code is:
C1418-78 - Vertical Misaligment senzor, on DASM Module
Removing the error did not solve the issue (aka one time error, it is reapearing)
abarthmultijet
Re: ACC Bosch Senzor aligment from MES?
Post by abarthmultijet »
At what control module does this fault appear?
callmemga
Post by callmemga »
Hmm, other/dasm it seems, i ve attached a picture
WhatsApp Image 2024-12-18 at 09.21.26_7057a13b.jpg (130.11 KiB) Viewed 3918 times
abarthmultijet
https://static.nhtsa.gov/odi/tsbs/2021/MC-10204352-9999.pdf
Did you have a look at this article?
