Alfa 147 - Proxy alignment failed
sszemtelen
Post by sszemtelen »
Hi Guys!
Alfa147 (2002):
The odometer has been changed from the small display to the larger version; since the factory clock died.
After replacement it flashes of course, but it won't let me do the Proxy alignment.
EcuScan is writing the file for Proxy connected devices:
Dashboard Node (IPC/NQS): EOL Failed
During proxy alignment, it writes these to the log:
EXECUTING ADJUSTMENT...
PROXY ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (IPC/NQS) FAILED! - Timeout error
Writing to module: Driver Door Node (NPG) SUCCESS!
FAILED TO EXECUTE
Someone wrote on EcuScan forum that he succeeded with a custom proxy, but he didn't enter the HEX code.
Maybe BCM should be updated somehow to recognize this kind of clock in it?
Thanks!
full log:
CAN CONFIGURATION DATA:
00 00 05 6B 00 00 05 6B 00 00 00 03 00 00 04 01 00 00 00 00
00 00 05 6B 00 00 05 09 00 00 05 6B 00 00 05 09 00 00 05 01
34 36 37 39 33 35 35 35 20 20 20 44 54 53 49 45 45 50 44 45 20 20 00 04 28 6B 05 00 00 09 05 00 00 00 00 00 08 06 00
Engine Control Node (ECM/NCM)
(Multiecuscan 5.1)
2024. 12. 08. 13:12:17
Alfa Romeo 147 1.6 TS 16V 105CV
Receiver Radio/Radio Navigator Node (NRR/RMN): Ok
Driver Door Node (NPG): EOL Ok
PROXI ALIGNMENT PROCEDURE
FAILED TO EXECUTE
