Change instrument cluster in Giulia
Landberg
Post by Landberg »
Is it possible to do the Proxy allignment with Multiecuscan for iPhone? When I see how the Proxy allignment is done after exchange of the instrument cluster I can see the OBD-cable is changed during the process. But with the Multiecuscan for iPhone I only got a dongle?
Re: Change instrument cluster in Giulia
If your Bluetooth dongle interface that you plug into the EOBD socket is not a multiplexing one the you need to plug the appropriate adapter cable in to EOBD socket and then your dongle into the end of that cable.
Note! I do not have MES for iPhone or use a Bluetooth interface so what I post above is what I believe I would do.
