is it possible to pair the key with its code modul? Which version of Mes do i need,which interface do I needed .I`ve seen there is a 3pin connector behind the fuses,just in front of the code-modul.
Error code is U1600, I have the key-code!
Car had already lost the connection about three years ago, After starting with the emergency -mode a few times, suddenly it started normal again.
