No DRL anymore on Fiat Tipo after retrofit Cruise control
MauHar
Post by MauHar »
Can anyone help me with the following:
I have here a Fiat Tipo 1.4 without cruise control. I bought a new steering wheel with cruise control buttons and do als a bcm swap from L0 to L1.
So everything, including the cruise control, works fine. The only thing is that i got a daylight error. The LEDs are not working and in the instrument panel is a light error. Apply it with MES and proxy does not make any difference.
However, when i swap the bcm L0 back in place, DRL is working fine.
chrener
Re: No DRL anymore on Fiat Tipo after retrofit Cruise control
Post by chrener »
Because of your new BCM is from different body type as original... For example BCM from hatchback type is not changeable into sedan and oposit...
Mobilemick
Post by Mobilemick »
Look into Config, see if it can be activated
