Proxy alignment fiat 500 1,2 8v
Hans Martijn
Post by Hans Martijn »
Beste mensen,
Kilometerteller knippert.
Heb nieuwe accu geplaatst. Massa verbindingen schoon gemaakt. Blue and me module is niet aanwezig, zie ook de kabel met connector niet, wel een Bury CC9058 Blue tooth carkit.
Kan proxy alignment niet uitvoeren met MES.
Krijg melding:
Connection failed
Unreliable communication detected
Check your cable and serialport settings
Bij Can setup/proxy alignment procedure:
In red: convergence telematic node (mode?) (CTM) EOL failed
HELP!
Translate by moderatorr
Dear people,
Odometer is flashing.
I have installed a new battery. Cleaned the ground connections. Blue and me module is not present, I also do not see the cable with connector, but I do see a Bury CC9058 Blue tooth car kit.
Cannot perform proxy alignment with MES.
I get the message:
Connection failed
With Can setup/proxy alignment procedure:
HELP!
abarthmultijet
Re: Proxy alignment fiat 500 1,2 8v
Post by abarthmultijet »
Hoi Hans Martijn.
Wat voor interface gebruik je?
TRANSLATION:
What interface do you use?
