No engine temperature option
Beluccina44
Post by Beluccina44 »
I would like to check my temp gauge in multiecuscan, but i can't find an option for that.. because it seems like my dashboard gauge has some failure. my car is a Giulietta 1.6 jtdm 2010
Re: No engine temperature option
If engine temperature is not a listed parameter on the dashboard connection (I see it is for the Siamens dashboard versions) then you will have to use the engine temperature on the engine ECU parameters.
