Abs alfa gtv
Alex916
Abs alfa gtv
Post by Alex916 »
How do I connect to the abs module? Car is a alfa gtv v6 turbo 1998 with 3-pin connector for engine reading. Do I use the same 3-pin connector to read the abs?
Thx
Re: Abs alfa gtv
Check the Supported Vehicles page: https://www.multiecuscan.net/SupportedVehiclesList.aspx
I see for Alfa Romeo GTV '98 2.0 V6 TB
Bosch Motronic ML4.1 Injection (V6 E.Key) |INFO|DTC|PRM| KL3-Pin
Bosch ABS 5.3 |INFO|DTC|PRM|ACT| KL A1 P1
TRW Airbag MY97 |INFO|DTC|PRM| KL A2 P3
Harrison climate control |INFO|DTC|PRM|ACT|ADJ| KL ELM A1 P9
This is saying that for ABS you require adapter A1 and for Airbag A2
Looks like you car has older 3 pin connection for the engine ECU and 16 pin OBD for ABS, Airbag and Climate
Alex916
Re: Abs alfa gtv
Post by Alex916 »
Ok thank you. I order some adaptors
Alex916
Re: Abs alfa gtv
Post by Alex916 »
I have the blue adapter with switch fir engine, abs or airbag. Will that work?
Re: Abs alfa gtv
Alex916 wrote: 10 Aug 2024, 18:00 I have the blue adapter with switch fir engine, abs or airbag. Will that work?
should work
