Hi Folks
New to this forum and searching for help please.
I have a 1998 Lancia Delta HPE 2.0 Turbo HF that is displaying the injector on the dash permanently and won't start. So far i've replaced the temp sensor that lets the ECU know the temp and the MAP sensor which hasn't made any difference.
I was hoping to be able to connect multiecuscan via my 3 pin connector and find out what the fault could potentially be. The engine code is 175A4000 which is the spec fitted to the '96 Fiat Coupe 2.0 16v Turbo and my ECU according to ePER is a Magneti Marelli IAW4WBP8AUP-HE
Hopefully, someone will know if it's possible to connect to this spec and exactly which adapters etc. will be required. I have the 3 pin adapter lead and have extended the power lead as my connector is under the bonnet and not in the car so just need correct adapters to connect to laptop. I hope this all makes sense. Thanks for reading.
Regards
Ian
