Central locking and indicators
Hello to all at forum! I'm new here. I just did proxi process after installing Abarth dash into 1.6 16V Fiat Stilo. Dash with color display. I did manage to adjust the ODO as well! I noticed, that after all that, indicators wont flash when I lock or unlock the vehicle. Is there an option inside MES where the indicators might got disabled during the process? Thank you
Re: Central locking and indicators
Connect to the Body Computer and look at Adjustments
For Marelli 192 then you need to use Alarm Mode (Country)
For Marelli 192FL MY08 then you need to use Indicators command
I did like you have posted. Then MES asked for electronic code, which I do have. That blue plastic card with electronic and mechanical code, also there is a sticker with radio CODE. Thank you very much, indicators now flash when operating central locking!
