Does anyone know whether you can read the AdBlue levels on a Ducato 250 2.3 (2021) model? I don't see it listed in the ENGINE Parameters section...
This vehicle does not have the digital dashboard.
Ducato 250 2.3 (2021) AdBlue (Urea) levels
abarthmultijet
Re: Ducato 250 2.3 (2021) AdBlue (Urea) levels
Select the Ducato 290, go to engine tab, do NOT go to engine ecu but go to Continental Urea/adblue dosing module. There you can see the level.
Perfect, thank you.
This leads on to a 2nd question...
The AdBlue fill light is on (yellow) but AdBlue level shows at 48.41%, 9.8283 litres and maximum 9.1720 litres (I.e. lower than the current level and with the light on!)
This doesn't make sense to me. Is it correct?
I understand that it's a 20 litre AdBlue tank and so maybe its the labels that are wrong in MuliltiECUscan. Still doesn't explain why the yellow light is on
abarthmultijet
You need to drive a certain distance for the light to reset. Could be around 10 km
This was before I filled up...
I was intrigued to find out how much Ad Blue was left when the light came on.
It seems to be either excessive usage or miscalibrated
