Proxi Alignment Fiat Ducato Series 8 (2022+)
linknet
Post by linknet »
I need to carry out a Proxi Alignment on my Fiat Ducato Series 8 (2022+) but when I scan the vehicle for available modules using MultiEcuScan there are 4 modules that are listed as UNKNOWN/USUPPORTED. I'm aware that the vehicle has a Secure Gateway Module and I've already installed a bypass which is working fine.
I would like to know before I purchase a licence whether a Proxi Alignment would complete satisfactorily bearing in mind that some of the modules are listed as unknown/unsupported.
Re: Proxi Alignment Fiat Ducato Series 8 (2022+)
unknown/unsupported means MES has not yet included those modules into it's description. usually proxi alignment works even with such modules but as it's new generation car you won't know until you try.
linknet
Post by linknet »
shpuncik wrote: 18 Jun 2024, 09:37 unknown/unsupported means MES has not yet included those modules into it's description. usually proxi alignment works even with such modules but as it's new generation car you won't know until you try.
OK, thanks for the information, it's probably worth a try then.
