Fiat Panda proxi alignment error after change dashboard
the_miracle
Post by the_miracle »
I changed basic dashboard on Fiat Panda 2008 1.1 for Emotion version with rmp and board computer and the proxi aligment finish with unknown error. The version of new dashboard is 51759896 and is it from year 2005. Do you have any tip, what I can do? Thanks. Martin
the_miracle
Re: Fiat Panda proxi alignment error after change dashboard
Here is the log:
CAN CONFIGURATION DATA:
00 00 00 0F 00 00 00 0F 00 00 00 0C 00 00 00 04 00 00 00 00
00 00 00 0F 00 00 00 09 00 00 00 0F 00 00 00 09 00 00 00 01
33 32 31 36 39 30 30 30 36 32 39 4F 55 54 50 55 54 4A 49 54 20 20 05 03 22 0F 00 00 00 09 00 00 00 01 00 00 00 00 01 14 00 00 00 04 06 01 00 00 00 00 00 00 11 00 04
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
(Multiecuscan 4.8)
13.06.2024 15:25:17
Fiat Panda '03 1.1 8V
Dashboard Node (IPC/NQS): EOL Failed
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (IPC/NQS) FAILED! - Unknown error
FAILED TO EXECUTE
