Trailer control module
Lali1234
Post by Lali1234 »
Hi i just bought a Stelvio 2019 and found that when using the towbar the parking sensors rear will not disconnect. Bougt Ecuscan with multiplexer. When connected to Bosch parking aid it was coded as no towbar. I altered it to towbar and close program. But it will not work! Same as before, now coded as towbar present. I also see if it was possible to alter in central electric modul but no option.
Need help!
Re: Trailer control module
most likely it depends on trailer module whether it's OEM or aftermarket. usually OEM disconnect parking sensors, aftermarket tow kits don't do that.
