[SOLVED] Cannot doing Datalogging > Disconnect from ECU when i select a parameter
Nixeus
Post by Nixeus »
Hello people,
I need to do some DataLogging and i have a problem with MES 5.0 and 5.1 ( registered).
I connect to my ECU ( 8GMK, Alfa Romeo Giulietta , 2015), once i check a parameter on the parameter list , to do datalogging, the ecu disconnect and the MES go back to the main page. Then, i cannot connect anymore, i have to quit and relaunch MES.
It's very frustrating because i cannot do datalogging.
Windows 11 , last driver.
I use this interface : Image
Need help please :)
Nixeus
Re: [SOLVED] Cannot doing Datalogging > Disconnect from ECU when i select a parameter
Post by Nixeus »
I finally solved this problem.
How ? Just reinstalled the last driver : https://ftdichip.com/wp-content/uploads/2021/08/CDM212364_Setup.zip
Then, in MES parameter i tooked the : ELM 327 1.3/1.4/1.4b/2.1 (High Speed) @ 38400 speed
> Datalogging is now ok.
( Btw i still cannot do the Neutral position learning > Incorrect condition to run this test). I was in neutral, i tested engine ON, engine OFF, but still the same "Incorrection condition to run this test" error).
Thanks for reporting back.
Often people find a solution / fix but don't bother to feedback. Your info will help others.
As for Neutral Learn - PASS however you could do the process again and submit a report to MES support and follow up with Email.
I is really frustrating when one gets messages like "incorrect conditions" with no further info. That said I doubt this is not MES not being more informative but likely a standard response from the vehicle ECUs that they don't like something but are not prepared to offer any further information.
Nixeus
Post by Nixeus »
s130 wrote: 28 Apr 2024, 09:39 Thanks for reporting back.
Haha yes, that's why i posted my solution there and i hope it will help somes.
Yeah about the incorrect conditions, i have pretty the same error in Alfa OBD :\
