Page 5 of 5
Posted: 15 Jan 2014, 17:35
Hello Soul Reaver
The resistor in the red Frame must you removed
- d272b0cab2a2902c0621a25ee1de6934 markiert.jpg (68.55 KiB) Viewed 10603 times
Posted: 15 Jan 2014, 17:55
by Soul Reaver
Thank you very much. I will try and report.
Posted: 19 Jan 2014, 17:00
by Soul Reaver
Hi.
I removed the resistor and tried again, but I can't connect.
I think that there's another problem... when i click "connect" in mes, after few seconds it tells me that it cannot reach target network destination.
Setups looks ok to me, I selected ELM 1-3+ bluetooth, port 20, speed 33xxx.
In windows in bluetooth devices I see OBD II device, and in properties it's set on com 20.
I also tried to instal "CDM 2.08.30 WHQL Certified" drivers.
What am I missing?
Thanks.
Posted: 19 Jan 2014, 18:34
Hello Soul Reaver
I'm sorry if my answer was not helpful.
But you have not described the problem?
and not on what vehicle?
and what control you want to access?
Have you first made the Bluetooth connection??
Because you have to first connect to the interface
and only then the connection to the vehicle
Posted: 20 Jan 2014, 07:50
by Soul Reaver
Hi Eddie.
Thanks for the reply.
Yeas, probably I missed some connection step.
My car is Grande Punto 1.9 130HP.
Using torque it works, but with Multiecuscan I can't connect.
I'm on windows 7 32bit.
I mean that when I press "connect" button I get a error, so yes, probably I did some mistake.
I checked com port and it should be ok, on pc in BT devices I can see ODB II, but I did not find where I can estabilish the connection.
Can you suggest me a link where i can see the steps to do before connecting Multiecuscan? thanks.
Posted: 20 Jan 2014, 18:17
Hello Soul Reaver
I have written about 2 years ago, a tutorial on installing a ELM 327 Bluetooth.
But only in German and have not yet had time to translate into English
But maybe guide will help you but
Posted: 21 Jan 2014, 08:36
by Soul Reaver
Alfaeddy wrote:Hello Soul Reaver
Installationsanleitung eines Interface ELM327 Bluetooth.pdf
Thanks, I think it will be enough.
I can't understand german, but it should be no problem.
