Multiecuscan 2.8.2 RELEASED!!!
Re: Multiecuscan 2.8 RELEASED!!!
angelootacon wrote: prejudice today, or try 2 interfaciue elm does not work and gives the same error ELM 327! Original!
Well, there is probably noise (or bad earth) or low power or something else with the CAN network of the vehicle.
Send me a report after the problem (using the red Send Report button). I will double check in the report to be sure that the problem is in the software or hardware.
angelootacon
Post by angelootacon »
ok I'll send you the report and let me know if you come and ok?
angelootacon
prejudice aspect News
you solved? :?:
michelespl
Re: Multiecuscan 2.8.2 RELEASED!!!
Post by michelespl »
I threw 50 in euro license multiecuscan thinking that place actually post allineamanto proxy on fiat punto mk2b MJT 2003, with latest multiecuscan elm1.4b official and the procedure begins and ends, but always display flashing dash! anyone tried on this car
michelespl wrote:I threw 50 in euro license multiecuscan thinking that place actually post allineamanto proxy on fiat punto mk2b MJT 2003, with latest multiecuscan elm1.4b official and the procedure begins and ends, but always display flashing dash! anyone tried on this car
Yes, the PROXI procedure works fine on Punto '99 and Punto '03.
Please send me a log file after PROXI procedure so that I can see where the problem is.
It could be a problem with the instrument cluster itself. Why did it start to flash?
angelootacon wrote: prejudice aspect News
you solved? :?:
Sorry, I did not see your messages here in this thread.
Anyway, I saw the report from your car and it cannot be programmed with standard PROXI procedure. The body computer appears to be virgin/unprogrammed. It needs a different programming procedure before doing PROXI alignment.
Why do you want to do PROXI alignment? Do you have any problem with the car?
angelootacon
you solved? :?:
I do alignment because Proxy or adding new accessories on the car navigation unit and connect nav window door
Ps .. an application so you can not do more training Proxy?
michelespl
I changed I went to the dash display with 3 lines with button menus;
place the two logs before and after repeating the same operation, the display will flash
FESLog_1105191934_FIAT PUNTO '03 1.3 JTD.txt
(1.38 KiB) Downloaded 466 times
FESLog_1105191930_FIAT PUNTO '03 1.3 JTD.txt
(1.38 KiB) Downloaded 482 times
Pechorin
Post by Pechorin »
Hi. I had FES v.2.5 .To upgrade to 2.8.2 should I pay again?
mattydr67
Post by mattydr67 »
No just download it and install it.
