Dunk_c
Post by Dunk_c »
Alex2610 wrote: 04 Jul 2021, 06:22 Hello, i constatly receive the "can bus" error in multiecuscan, the test gives all ok back.
Scanmaster dectects the ECU, multiecuscan does not.
Photos
I just bought a similar interface (at least the main side of the board). Installed the CH304 driver on my old XP laptop.
MES connects to the car using this interface but does not show any live parameter values. Did you get yours going?
fantictt4@gmail.com
Post by fantictt4@gmail.com »
Salve chiedo a voi esperti perché non riesco neanche a superare la fase di test con multiecuscan e via alkego le foto interne dell'interfaccia acquistata su AliExpress r dopo varie ricerche non trovo nulla di simile,dimenticavo devo connetermi sul bodycomputer per fare la modifica del serbatoio carburante da 60 a 90 lt. su fiat ducato x290 del 2019
Mxman23
Post by Mxman23 »
https://ibb.co/c8R9rMW
https://ibb.co/PmfNrHW
Need help with what resistor to remove thanks in advance
Ppao
Post by Ppao »
i have problems with connection to a fiat 500x 1.4 T-JET/MULTIAIR. I have a elm327 module 3.0 since about 10 years and never problem with the old cars.
But today i can connect to this fiat in order to clear maintenance indicator. When i connect to service/service interval reset (334), i have a execution error message. I can connect to the engine without problem
my multiecuscan version in 4.9 registered.
May be i should have a multiplexed version ?
Have you used the correct adapter cable? No:3 / Yellow
Fubuki28
Post by Fubuki28 »
Hi, I am asking for help with my odb2. It only connects to the ecu for 5 seconds then crashes and disconnects in every program and application. This is obd2 "ymiot b18-3 wifi". And the car is a Fiat Bravo 2.
https://imgur.com/a/RgaGje8
https://imgur.com/a/zWh9gjg
https://imgur.com/a/DRgmTom
Ppao
Post by Ppao »
s130 wrote: 04 Dec 2022, 18:17 Have you used the correct adapter cable? No:3 / Yellow
Thank for your answer
I think so. i try to connect the yellow cable but it does not work.
roby89br
Post by roby89br »
Hi, i have this eml 327 BT interface, I also bought a yellow cable for my Giulietta.
What I have to modify?
Thz
I wasn't able to upload photos.
https://mega.nz/file/sEEATJbT#ZZg2x1cU5D_xTHnNmwwPtSKqepDzLa9ReC9tbtnU8eI
ishipuri
Post by ishipuri »
First, about machine translation
there may be a problem with the translation
very sorry
good evening everyone or hello
My favorite car is Alpha Mito 1.4 Turbo
Can't connect due to interface problem, image error
I would appreciate it if someone could help me
the interface is an image
I tried to take it apart but I don't understand
This interface also
Is it possible to connect by replacing resistors, capacitors, etc.?
ishipuri
Post by ishipuri »
hello
This is what I posted yesterday
Red/yellow/blue cables supplied with the interface
No... my yellow cable to the item of the airbag
I was able to access
It's supposed to be red, right?
My problem is the airbag warning light
So I solved it for the time being・・・
OK  sorry for bothering you
