i have an alfa romeo giulietta and i can't connect the elm327 via the yellow cable.
Can you help me please what modify i must make?
https://ibb.co/r2f3h9w
https://ibb.co/Jtn8nRC
I have viecar Bluetooth 4.0 OBD2 protocol 1.5.
I need remove resistor 120 ohm in position image atached and jumper betwen pins 1,3,7,8 and 9,11, 12, dont make jumper in pins 1 and 9.
My car is Siena 1.0 year 2014 Brazil.
Instrument Panel Continental and engine module G4F.
I have free access from ALL modules, after modification in OBD with multiecuscan and AlfaOBD.
For Proxy aligment i select Strada 1.4 in multiecuscan, all rigth in my car.
Follow the link in Aliexpress, delivery in 13 days to Brazil.
R$ 44,74 25%de desconto | Viecar-leitor de código obd2, diagnóstico via bluetooth 4.0, elm327, ios, android, pc elm 327 v1.5, interface de diagnóstico
OBD Viecar Link
https://a.aliexpress.com/_msVSbeT
Image viecar resistor 120 ohm
https://ibb.co/d74xQXJ
Image Need Jumper
https://ibb.co/TryJP6D
Good Luck for ALL.
OBD Viecar Link
Image Need Jumper
Good Luck for ALL.
Bom dia, estou tentando conectar a ECU do meu FIAT STILO 1.8 8V, o elm327 1.5 está comunicando como pode-se ver no teste abaixo, porém quando eu conecto na ECU, não aparece nenhuma informação, e simplesmente não responde aos comandos, mas a conexão é feita com sucesso, sem falhas. Simplesmente não atualiza as informações. Estou sem cotas para anexar arquivos de imagem para que seja possível um melhor entendimento do meu problema. Peço gentilmente a ajuda de vocês.
RESPONSE: ü
ELM327 v1.5
ELM327 v1.5
RESPONSE: ü
ELM327 v1.5
ELM327 v1.5
does anyone have experience with this ELM 327? Which resistor needs to be desoldered to work on the Lancia?
Thank you
Thank you
hi, this tool connects only to the engine control unit, I have another modified tool where it was easy to locate the 120 ohm resistor, please can you tell you how to unlock these new models .. thanks
https://ibb.co/fHzn0KM
https://ibb.co/RCMPNxB
Hello everyone!!
Could any body help with ELM 327 USB adapter ?
How i understand, for can reading i need to remove chip R04 or R14 ?
In picture below, there is elm 327 board, i bought ver 1.5, but on board sign is ver 1.0 ???
Will it work, or i need to buy another one ?
First post here.
I'm comming from Android & Windows to iOS 15 and MacOS 11,8 ,
I have like 10-11 OBD2 items, mainly bluetooth but somes are Wifi for iOS.
Bluetooth are OK with Android but ton iOS
Any of my OBD2 Wifi works with Multiecuscan iOS
I just bought a MES OBD2 Wifi on Multiecuscan.it, this one https://www.multiecuscan.it/en-us/multiecuscan-ios-elm-327-wifi-iphone-ios/
Hope this one will works with my Iphone 12 Pro Max coz we cannot use Bluetooth OBD (if they aren't OBDLink MX+ over 120 EUR)
I'll back with my result.
First post here.
Hi i have a fiat Stilo. i connect Fiatecuscan 3.6 with a ELM 327 1.3+ clone. all works fine, except for some functions that has strange behavior.
for Example steering wheel align : when start procedure and FES instruct to move steering on left after 1 sec without time to move procedure ends and FES return on main menu.
In this days i have some issue with alarm and i want to turn off. On FES Menu i have to input Electronic code and always receive "code not valid"(but i write original code from card).
Strange is that after three times i should have to wait 30 mins, but this is not true. i can try as often as i want.(always same error).
I don't understand if it is a FES issue or a ELM issue.
Thanjks for answer
Thanjks for answer
I have the same unit and it connects to the engine and gearbox modules but no others.gtxstunt wrote: ↑29 Sep 2021, 12:37 Hello everyone!!
I am considering correcting it but was going to remove R2 as this is the only 121 ohm resistor on the board.
