jpan
Post by jpan »
i have an alfa romeo giulietta and i can't connect the elm327 via the yellow cable.
Can you help me please what modify i must make?
https://ibb.co/r2f3h9w
https://ibb.co/Jtn8nRC
welton
Post by welton »
I have viecar Bluetooth 4.0 OBD2 protocol 1.5.
I need remove resistor 120 ohm in position image atached and jumper betwen pins 1,3,7,8 and 9,11, 12, dont make jumper in pins 1 and 9.
My car is Siena 1.0 year 2014 Brazil.
Instrument Panel Continental and engine module G4F.
I have free access from ALL modules, after modification in OBD with multiecuscan and AlfaOBD. :lol:
For Proxy aligment i select Strada 1.4 in multiecuscan, all rigth in my car.
Follow the link in Aliexpress, delivery in 13 days to Brazil.
R$ 44,74 25%de desconto | Viecar-leitor de código obd2, diagnóstico via bluetooth 4.0, elm327, ios, android, pc elm 327 v1.5, interface de diagnóstico
OBD Viecar Link
https://a.aliexpress.com/_msVSbeT
Image viecar resistor 120 ohm
https://ibb.co/d74xQXJ
Image Need Jumper
https://ibb.co/TryJP6D
Good Luck for ALL.
joaofernandes
Post by joaofernandes »
Bom dia, estou tentando conectar a ECU do meu FIAT STILO 1.8 8V, o elm327 1.5 está comunicando como pode-se ver no teste abaixo, porém quando eu conecto na ECU, não aparece nenhuma informação, e simplesmente não responde aos comandos, mas a conexão é feita com sucesso, sem falhas. Simplesmente não atualiza as informações. Estou sem cotas para anexar arquivos de imagem para que seja possível um melhor entendimento do meu problema. Peço gentilmente a ajuda de vocês.
RESPONSE: ü
ELM327 v1.5
ELM327 v1.5
keram25
Post by keram25 »
does anyone have experience with this ELM 327? Which resistor needs to be desoldered to work on the Lancia?
Thank you
elmer
Post by elmer »
hi, this tool connects only to the engine control unit, I have another modified tool where it was easy to locate the 120 ohm resistor, please can you tell you how to unlock these new models .. thanks
https://ibb.co/fHzn0KM
https://ibb.co/RCMPNxB
gtxstunt
Post by gtxstunt »
Hello everyone!!
Could any body help with ELM 327 USB adapter ?
How i understand, for can reading i need to remove chip R04 or R14 ?
In picture below, there is elm 327 board, i bought ver 1.5, but on board sign is ver 1.0 ???
Will it work, or i need to buy another one ?
Twostep
Post by Twostep »
First post here.
I'm comming from Android & Windows to iOS 15 and MacOS 11,8 ,
I have like 10-11 OBD2 items, mainly bluetooth but somes are Wifi for iOS.
Bluetooth are OK with Android but ton iOS
Any of my OBD2 Wifi works with Multiecuscan iOS
I just bought a MES OBD2 Wifi on Multiecuscan.it, this one https://www.multiecuscan.it/en-us/multiecuscan-ios-elm-327-wifi-iphone-ios/
Hope this one will works with my Iphone 12 Pro Max coz we cannot use Bluetooth OBD (if they aren't OBDLink MX+ over 120 EUR)
I'll back with my result.
stiloMjt
Post by stiloMjt »
Hi i have a fiat Stilo. i connect Fiatecuscan 3.6 with a ELM 327 1.3+ clone. all works fine, except for some functions that has strange behavior.
for Example steering wheel align : when start procedure and FES instruct to move steering on left after 1 sec without time to move procedure ends and FES return on main menu.
In this days i have some issue with alarm and i want to turn off. On FES Menu i have to input Electronic code and always receive "code not valid"(but i write original code from card).
Strange is that after three times i should have to wait 30 mins, but this is not true. i can try as often as i want.(always same error).
I don't understand if it is a FES issue or a ELM issue.
Thanjks for answer
Alfa_147_Sele
Post by Alfa_147_Sele »
gtxstunt wrote: 29 Sep 2021, 12:37 Hello everyone!!
I have the same unit and it connects to the engine and gearbox modules but no others.
I am considering correcting it but was going to remove R2 as this is the only 121 ohm resistor on the board.
studiotrenta
Post by studiotrenta »
brulkjaer wrote: 02 Nov 2018, 14:27 Image
This is my interface.
Witch resistor must be removed?
Hi, have you found which resistor has to be removed?
