Hello everyone,
i have a Fiat Punto 1.3 multijet, i bought elm v1.5a.
When i try to connect to Mes not working.
See the immages at http://imgur.com/a/tmE5S
How resistor should I remove?
Thanks for help
Thanks for help
I suspect R2 is the bridge resistor
but since you can only guess I just a picture of a page have.
It is also helpful if you set a screen of the interface test here.
Hello Sardegna
For the reason, a screen of the interface test is so important
as already written several times the interface since 2015 only
rarely with MES Works
Sorry for my English.
Fiat Panda 2008 dialogic (selespeed)
ELM 327 WI-FI USB
wires suitable for pin 2,4-5,6,7,9,14,16
reads transmission - gearbox, removes (delite) the error codes , but does not do service work on the clutch calibration torirovaniyu and other works , removes the error codes , but does not do service work on the clutch calibration torirovaniyu and other works.
Thanks for help
https://drive.google.com/file/d/0BxHjrm ... sp=sharing
ELM 327 WI-FI USB
Thanks for help
Hi all,
I am hoping you can help me out I am trying to get a elm327 working on JT850 PWM and I am having no luck I am hoping someone here may be able to help me out I am attaching photos of the PCB.
Thanks,
Yonu
Thanks,
Yonu
Hello. Can somebody help me which resistor I need to destroy to connect my car's dahsboard. I need proxy alignment. Alfa Romeo 147 1,9 JTD
https://photos.google.com/share/AF1QipP ... R3U2NMU093
Thanks for the help
Thanks for the help
I just want to by on e-bay proper interface that I can use for things I explained in my other post on wrong topics. It is for Fiat bravo '08, 1.9 16V. So what to look for on ebay? If you can send me a link, it would be great. I prefer bluetooth, but if there isn't any of it USB is fine too.
So is it something this:
This interface: http://www.ebay.com/itm/Auto-V2-1-Inter ... SwKfVXD8wb
+ this A1 adapter cable:
http://www.ebay.com/itm/Diagnose-Adapte ... OSwDk5ULac~
Whit this I can access to engine, ABS, ESP, airbag modules etc...
Have you ever seen this elm327 1.5 PCB ?
USB communication is ok but no connection to OBD (tested on a Fiat Punto 1.3 JTD Blue&ME 2011 and with EasyOBD, with and without adapter 3 (yellow)).
No result with "Scan for Interfaces" feature in Multiecuscan settings.
Where is the resistor to cut ? (R14???)
http://s32.postimg.org/f1k370ok5/20160428_203842.jpg
http://s32.postimg.org/r0vlebu51/20160428_203913.jpg
