Sardegna
Post by Sardegna »
Hello everyone,
i have a Fiat Punto 1.3 multijet, i bought elm v1.5a.
When i try to connect to Mes not working.
See the immages at http://imgur.com/a/tmE5S
How resistor should I remove?
Thanks for help
I suspect R2 is the bridge resistor
but since you can only guess I just a picture of a page have.
It is also helpful if you set a screen of the interface test here.
Sardegna
Post by Sardegna »
Thanks Eddie,
this is the interface http://imgur.com/SUHjgft.
I removed the R2 but nothing...
Hello Sardegna
For the reason, a screen of the interface test is so important
as already written several times the interface since 2015 only
rarely with MES Works
zhbrrjh
Post by zhbrrjh »
Sorry for my English.
Fiat Panda 2008 dialogic (selespeed)
ELM 327 WI-FI USB
wires suitable for pin 2,4-5,6,7,9,14,16
reads transmission - gearbox, removes (delite) the error codes , but does not do service work on the clutch calibration torirovaniyu and other works , removes the error codes , but does not do service work on the clutch calibration torirovaniyu and other works.
Thanks for help
https://drive.google.com/file/d/0BxHjrm ... sp=sharing
yonubear
Post by yonubear »
Hi all,
I am hoping you can help me out I am trying to get a elm327 working on JT850 PWM and I am having no luck I am hoping someone here may be able to help me out I am attaching photos of the PCB.
Thanks,
Yonu
balu807
Post by balu807 »
Hello. Can somebody help me which resistor I need to destroy to connect my car's dahsboard. I need proxy alignment. Alfa Romeo 147 1,9 JTD
https://photos.google.com/share/AF1QipP ... R3U2NMU093
Thanks for the help
us911
Post by us911 »
A good link is www.electronic-fuchs.de
Die sprechen deutsch. :lol:
luka78
Post by luka78 »
I just want to by on e-bay proper interface that I can use for things I explained in my other post on wrong topics. It is for Fiat bravo '08, 1.9 16V. So what to look for on ebay? If you can send me a link, it would be great. I prefer bluetooth, but if there isn't any of it USB is fine too.
So is it something this:
This interface: http://www.ebay.com/itm/Auto-V2-1-Inter ... SwKfVXD8wb
+ this A1 adapter cable:
http://www.ebay.com/itm/Diagnose-Adapte ... OSwDk5ULac~
Whit this I can access to engine, ABS, ESP, airbag modules etc...
albert
Post by albert »
Have you ever seen this elm327 1.5 PCB ?
USB communication is ok but no connection to OBD (tested on a Fiat Punto 1.3 JTD Blue&ME 2011 and with EasyOBD, with and without adapter 3 (yellow)).
No result with "Scan for Interfaces" feature in Multiecuscan settings.
Where is the resistor to cut ? (R14???)
http://s32.postimg.org/f1k370ok5/20160428_203842.jpg
http://s32.postimg.org/r0vlebu51/20160428_203913.jpg
