Odometer EDC15
Re: Odometer EDC15
Odometer:-----------Dashboard:
3 624 043------------105 302
3 750 420------------108 974
3 769 340------------109 524
3 810 201------------110 710
I pass 36,4 km
3 811 457------------110 747
my ECU http://www.postimage.org/image.php?v=aV1OZmF9
value = 0.029056
"Odometer", 1, "Odometer", 1, "#scaling unsigned 3 X*0.029056 km";
may it be?
I pass 36,4 km
value = 0.029056
may it be?
Re: Odometer EDC15
kecka wrote:program Stilo jtd has a menu 2x odometer and each shows me otherwise ?????
Re: Odometer EDC15
This is my first post in this forum, so first of all: Congratulations for the great work and efforts you put in this software! Keep the good work!
Here is my feedback on the Odometer topic. There are several examples:
Driven distance, according to daily dashboard: 7.9
Odometer delta: 65 (1668911-1668846)
Driven distance, according to daily dashboard: 53.2
Odometer delta: 425 (1669336-1668911)
Driven distance, according to daily dashboard: 55.8
Odometer delta: 471 (1669932-1669461)
Driven distance, according to daily dashboard: 136
Odometer delta: 1086 (1669932-1668846)
As you can see, the coefficient Odometer delta / Dashboard delta is not constant. Generally, it looks like the coefficient is around 8 for my ECU. This means that the real km for my ECU should be calculated as odometer reading divided by 8.
I'm very curious what exactly stays behind this Odometer value. Why it's change ratio doesn't correspond to the actual change ratio of the dashboard? Why the coefficient Odometer delta / Dashboard delta is not constant for the same vehicle in different moments?
Here is a screenshot of my EDC data: http://img641.imageshack.us/img641/9395 ... creen2.jpg
The car is Lancia Lybra 2.4jtd '00, 839A5.000
Lybra 2.4JTD SW, 839A5.000
						Re: Odometer EDC15
"Odometer (2)" is the value of the odometer at the last time when your ECU was reprogrammed.kecka wrote:kecka wrote:program Stilo jtd has a menu 2x odometer and each shows me otherwise ?????
Re: Odometer EDC15
What do you mean??
						Re: Odometer EDC15
Není to stav kilometru, kdy jsi dělal flashování ř.j. ?kecka wrote:What do you mean??
Re: Odometer EDC15
no delal jsem to vice krat......     zkusim to flesnout a uvidime ....
						Re: Odometer EDC15
I tested my Brava 1.9 JTD 105 CF2.
I drove for a while and here is the result:
- dashoard value increased 111,2km
- odometer value increased 3827
We divide 3827/111,2 = 34,4
So the odometer value needs to be divided by 34,4 and we have real value
Re: Odometer EDC15
What is your ISO code?klocek14 wrote:I tested my Brava 1.9 JTD 105 CF2.
Re: Odometer EDC15
FD 86 85 98 75What is your ISO code?
