The problem is not a bridge resistor
with this interface, you can not connect to your car ??
produced with MES
Since the software on the chip is not compatible with MES.
You need another interface
produced with MES
Is there a list of proven chips/layout or interefaces itself that are compatible with MES? I am still considering of buying one of cheaper solutions that could be modified. It's would be cheaper (6 -10 Euros) , while modified ELM cost ~26 EUros.Alfaeddy wrote:Hello
produced with MES
Does anyone has an ebay link of ELM interface that has been successfuly modified and works?
This one with usb
http://www.ebay.de/itm/161830477630?_tr ... EBIDX%3AIT
and this one with BT
http://www.ebay.de/itm/151841232185?_tr ... EBIDX%3AIT
greetings Eddy
						This one with usb
greetings Eddy
Hello everyone. In search of a solution to my problem was found here. Many there is such a problem. I bought elm327 USB chip ch340t. Problem connect to multiecuscan. Team ATSPC - timeout. The same problem with fiatecuscan. The program scanmaster connects immediately. Tested STN Term, all teams are normal. There is a solution to this problem?
Hi !
Can't connect as you can see below ... does that mean I have to get another cable ? If so, witch one works right out of the box ?
sorry screenshots are in french
http://imgur.com/BcqLjGr
http://imgur.com/HqVifd2
http://imgur.com/27meu09
				pogano_celjade
I have Chinese ELM 327 usb V1.5a and can't connect him to car in MES. I tried to remove R2 121 resistor (marked red on image) but nothing changed. Wires is for switch, ignore them.
http://s8.postimg.org/ut7rp0y1h/IMG_20160211_210531.jpg
http://s24.postimg.org/wz1afg2o5/IMG_20 ... 116803.jpg
http://s8.postimg.org/s3gtasuvp/IMG_20160211_212018.jpg
Hello Pogano Celjade
Which driver you have installed?
Take this driver
Have you asked the Latency Time to 1 ??
Which vehicle you want to read ??
The remote resistor has nothing to do with the general function.
It is only relevant for the CAN bus protocol
Take this driver
				pogano_celjade
Thanks for reply Alfaeddy.
Driver is CH340, I can't install FTD driver.
How to change latency? I'm using Win 10.
I want to read the Alfa 147. But I can't even do a test in MES.
Hello Pogano
Device Manager / Com Ports / USB serial port / properties / extended / Latency Time
drop down the value from 16 to 1 box set
How to change latency? I'm using Win 10. Device Manager / Com Ports / USB serial port / properties / extended / Latency Time
Hello  Adelscott
Unfortunately, I can not see why this error is displayed.
As should operate this function without error after your screen
Have you ever tried to draw the OBD connector and after a few Sec.
connect it again?
Then if the same fault has occurred?
connect it again?
